edahari52
Apr 18, 2022Aspirant
On time backup
Hi. I have problem with real-time backup after few weeks some of my folders stop to backup. How to fix it. Thanks Eytan
edahari52
Hi. thank you for the replay.
Source: Folders in my computer.
target: My ReadyNas 214.
tools: ReadyCloud.
furmware: 6.10.7 (arm)
Apr 18, 2022Guru - Experienced User
Is the PC running Windows 10?
- edahari52Apr 18, 2022Aspirant
win 11.
- JeraldMApr 20, 2022NETGEAR Employee Retired
Hi edahari52,
Thanks for the ping StephenB!
Were there any events that might have caused the issue? For example, did the issue occur when you upgraded to Windows 11?
Also, if possible, have you already tried re-enabling ReadyCLOUD on the ReadyNAS and reinstalling the ReadyCLOUD application?
If the issue still persists, please send me the logs via PM to further assist you.
JeraldM
NETGEAR Community Team
- edahari52Apr 27, 2022Aspirant
Hi. This case happened to me at Windows 10 and 11.
After an irregular time randomly, the folders are stop to backup.
I Have to create new pc folders to backup.
Thanks
Eytan
