mmeyer0312
Jul 09, 2023Follower
orbi 690 & RN3138 NAS
Moved across country and brought my RN3138 NAS with me... At new location, I now have a ORBI 690 6E router w/2 satellites.. I connected my NAS to the network and can not access it. I finally go...
schumaku
Jul 10, 2023Guru - Experienced User
Temporarily change your MBP to an IP address in the 192.168.0.x/24 range like 192.168.0.123 mask 255.255.355.0 gateway and dns for example to 192.168.0.1. Now you should be able to access the NAS again and change the IP address e.g. to DHCP so it will get an IP config assigned from the Orbi 960 router. Revert the MBP config to DHCP.
- StephenBJul 10, 2023Guru - Experienced User
There are two other ways:
- change the Orbi LAN network temporarily to 192.168.0.x. Log into the NAS and change it to use DHCP.
- do an OS reinstall from the front panel of the NAS
See pages 44-47 for info on the OS reinstall.
It will
- change the network config of to DHCP with no bonding
- reset the admin password to password.
- disable volume quota (can be re-enabled from the settings wheel on the volume tab)
