e_John
May 10, 2019Aspirant
OS 6.10 Hotfix 2 installed, cannot see shares on Win network
We have been running our ReadyNAS successfully for a few years. Updated the OS this week, and now the shares and the entire ReadyNAS are not available, not visible with SMB. Yes, I can get to the d...
schumaku
May 10, 2019Guru - Experienced User
Calling //ReadyNAS from Windows Explorer will open a Web browser, and show the same result if calling the same in a Web browser. WIndows does take this as shortcut for an URL, like https://ReaeyNAS
Calling \\ReadyNAS or \\redynas\photos will give access to the NAS shared folders.
Complete unrelated to the ReadyNAS - plan standard Windows.
e_John
I think you did not understand the issue.
READYNAS is not accessible on the network. It is fully accessible by IP address.
- schumakuMay 10, 2019Guru - Experienced User
Well, hard to understand as you said...
"Yes, I can get to the device and see the shares by accessing //ReadyNAS, but that gives me the console,"
...so that does not read like a name resolution thing.
Windows 10 can use WS-Discovery, NetBIOS (permitting SMB 1.0/CIFS feature is installed), and DNS for the name resolution.
For the discovery so the ReadyNAS does become visible in Windows Explorer, WS-Discovery (default on in RN OS 6.10) and NetBIOS (needs to be enabled on both sides - Legacy Windws Discovery in the RN SMB settings, SMB 1.0/CIFS Client feature on Windows).
These will show up in the "Network" section as a PC/System/Computer
This I definitively can't understand. IP doesn't use the netowrk?
- StephenBMay 10, 2019Guru - Experienced User
Well, you started by saying that entering //readynas opened up your web browser.
schumaku replied by telling you that is how Windows works. If you want to access a share in file explorer you need to enter \\readynas\photos. Perhaps you just typed the wrong slash?
- e_JohnJul 21, 2019Aspirant
@schumaku replied by telling you that is how Windows works. If you want to access a share in file explorer you need to enter \\readynas\photos. Perhaps you just typed the wrong slash?
No, not that easy. I just cannot access ReadyNAS as a device. I can access it by IP address, and it shows up in the Windows Network, but cannot access it. Sounds like either a NETBIOS or DNS thing, but not finding it. Only common denominator was the upgrade in OS.
- StephenBJul 21, 2019Guru - Experienced User
Try running CMD (by typing CMD in the windows search bar)
Then enter
net use * /delete /y net use t: \\nas-ip-address\data /user:admin nas-admin-password
Use the actual NAS ip address and nas admin password of course. Be careful on the typing (particularly slash directions and spaces).
The first command terminates any open network sessions. The second command attempts to mount the NAS data volume as drive letter T. Note that data is the NAS volume name when you use XRAID. If you are using FlexRAID, you would need to substitute whatever volume name you entered when you created the volume.
Let us know whhat happens with these commands.
