PerfectOnline
Dec 19, 2018Tutor
OS6 on a legacy device in 2018.
Hello there NAS-owners. Starting this thread instead of me going off topic in the thread about ’restriping’. I just switched from OS4 to OS6 and so far i am happy with the change. The new OS is ...
Retired_Member
Dec 20, 2018PerfectOnline wrote: "When i was resyncing drives perhaps an hour ago it was around 50c for the CPU and for the system it peaked at 62c, that’s not optimal if you ask me."
Do you recall the temparature of the disks at the time you measured the above?
Kind regards
PerfectOnline
Dec 20, 2018Tutor
I sure do, they were around 34-36c.
I really need to open it up and have a look. When replacing the 12cm fan, it is a PWM fan right? I think i’ve read that somewhere.
- StephenBDec 20, 2018Guru - Experienced User
I really need to open it up and have a look. When replacing the 12cm fan, it is a PWM fan right? I think i’ve read that somewhere.3-pin PWM. I replaced the one in the Pro-6 with a Noctua NF-S12A FLX.
But keep in mind that the temp reports might be reported incorrectly. Hopefully another Ultra-6 user running OS 6.9.4 will chime in.
- TeknoJnkyDec 20, 2018Hero
not sure how close they are in hardware, but my ultra 4 temps are;
disks: 34 to 41c
cpu fan 1318
system fan 1016
cpu temp 51c
sytem temp 61c
profile quiet
load: idle (its only a backup destination now)
- PerfectOnlineDec 20, 2018TutorHm, i don’t think three pin PWM exists, i could be wrong though. I just spent my evening cleaning the NAS and it wasn’t a pretty sight in there, clean almost the entire inside of the box and i checked the 12cm fan and sure enough it was a three pin connection, i replaced the fan with a three pin Lian-Li fan i had as a spare and the system reads it, correctly i hope.
There is a chip on the motherboard with a heatsink on, i guess it is the CPU, that had old thermalpaste on it, it was like hard clay, i removed that and applied some thermalpaste from EKWB that i think is a good paste for such things.
I had liquid metal but i didn’t have the balls to apply that since it is conductive. Would have loves to see the temp readings after that though.
Oh, and i had two sticks of Kingston 2gb DDR-2 laying around so i installed those and yes: the system now runs at 4gb RAM (almost 4 that is according to the system). In other words: 4gb works. Not sure if 2x4gb would work, would be cool though.- PerfectOnlineDec 20, 2018TutorAfter applying new thermalpaste and replacing the fan the temps are:
Drives: 32c-34c.
CPU: 35c.
System: 56c.
Fan RPM: 786 (on Cool).
Not sure why system temps are that high, i cleaned both the PCB’s with isopropylalcohol.
