PerfectOnline
Dec 19, 2018Tutor
OS6 on a legacy device in 2018.
Hello there NAS-owners. Starting this thread instead of me going off topic in the thread about ’restriping’. I just switched from OS4 to OS6 and so far i am happy with the change. The new OS is ...
Dec 20, 2018Guru - Experienced User
PerfectOnline wrote: "When i was resyncing drives perhaps an hour ago it was around 50c for the CPU and for the system it peaked at 62c, that’s not optimal if you ask me."
50c for the CPU is quite normal, 62C for the system is not. In addition to the disk temps:
- Where you monitoring temps with 4.2.31, and if so what temps were you seeing under load?
- What speed was the chassis fan running at during the resync?
- What cooling profile did you choose (quiet, balanced, or cool)?
Maybe post the temp graph on the performance page.
Note you can test again by running a scrub from the volume maintenance settings wheel - that will create a load that is similar to a resync.
It is possible that the chassis fan needs to be replaced. Of course dust could also be interfering with cooling, so if you haven't looked for that lately, you might want to do that.
PerfectOnline
Dec 20, 2018Tutor
The temps under OS4 was around 34-37 for the drives, something like 43 for the system and 50-57c for the CPU. Something like that.
I remember that the CPU was climbing up to perhaps 58c at one time.
During the resync now i changed it to Cool and it was running at around 900-1100rpm.
Mostly above 1000rpm.
Yes, i’m going to open it and have a look. I want to replace the fan for a fan with alot of pressure and rpm, it is PWM right?
