jolo2's avatar
jolo2
Star
Jul 07, 2019
OS6 USB Reinstall on Pro 6 (legacy, upgraded)?
I have shut myself out of my Pro 6.  (It seems the email server was switched off, so the password reset doesn't work.)  I think there are two options:   1.) To use the USB Recovery Tool (https://kb...
  • bedlam1's avatar
    Jul 07, 2019
    Your Option 2 will work fine, the Admin password will change to the default of password
    Some other settings may change too, like quotas being switched off, check your network settings too
ProSupport for Business
