fabsett
Jul 06, 2015Aspirant
Partition problems after crash
the following problem I have .... My Nas was about to defragmetieren all my disk until suddenly the power went out and then on all hard disks unfortunately the partition table are messed up Now I ha...
Jul 06, 2015Guru - Experienced User
I'd contact support (even though they will likely need to charge you).
If you do too much on your own you are likely to do more damage.
