Eilonwy's avatar
Eilonwy
PC not found NAS eSATA connect
Hi
I have Netgear nas RN102 (firmware6.4.1) // PC - Win 7/ Motherboard Asus Rampage formula - Intel X48 / latest bios Version 1001.  https://www.asus.com/Motherboards/RAMPAGE_FORMULA/specifications/
When you connect the NAS to motherboard using a cable SATA / eSATA  in the bios or in windows do not find NAS. :////
How do connect NAS and PC for transfer 1TB dat (photo) -- through the LAN it is extremely long :/
Thanks for the answer why not find NAS Connection via SATA :)
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The NAS is not an eSATA/USB peripheral. The eSATA port is for connecting an external hard drive to the NAS.
    The NIC (ethernet port) is used for connecting the NAS to your network.
    Are both your NAS and PC connected to a gigabit router/switch?
    What services and apps are you running on your NAS?
    • Eilonwy's avatar
      Eilonwy
      THX for answer
      Motherboard - Gigabit LAN
      Tenda router N60 - Gigabit LAN
      Cable - UTP cat.6 / 2m + 10m
      in the NAS 2x 3TB WD red - WD30EFRX
      I have instaled in NAS only 2 aplication -  PLEX a Bit Torrent Sync // not running when copy data
      copy with error
      copy without error  // 700GB  = 700 000 MB  / 700000/4,3/60/60 =  +- 45hours....
      • BrianL2's avatar
        BrianL2
        Hi Eilonwy,
        Either you access the NAS via File Explorer to copy and paste files or create a backup job through the built-in backup manager in the admin page.
        Kind regards,
        BrianL
        NETGEAR Community Team
ProSupport for Business
