JohnNulty
Mar 23, 2015Apprentice
Piwigo Upgrade?
Hi S-P,
Piwigo has been updated to 2.7.4 with some good stuff, including security fixes. Your original port was 2.5.3. Please provide advice on how to upgrade without trashing the current database. The 'automatic' upgrade process offered by the Piwigo.org site is a bit risky. Can you please confirm that the manual upgrade, described here: http://piwigo.org/basics/upgrade_manual, should work with OS6, on my RN312. If not, is an OS6 packaged update required (from you, if possible)? Always grateful for your continued support.
- JohnNultyApprenticeHi S-P,
Works like a dream - many thanks! - super_poussinVirtuosohello
backup all your data just in case and use the new Haddon in the community dropbox (it works on my units :) ) - JohnNultyApprenticeHi S-P,
I can bet you are busy, but have you had any time to look at this? - super_poussinVirtuosoWill take a look
- Aug 18, 2018Retired_Member
