jelockwood1
Jul 29, 2011Guide
Please port forked-daapd to ReadyNAS to replace Firefly
Currently like all other NAS boxes, the ReadyNAs uses the obsolete Firefly (aka. mt-daapd) code. This still works (just) as a very basic music sharing server to iTunes clients, but does not support newer features like Apple Remote, Apple TV, AirPlay, etc. etc. features. Firefly (and the mt-daapd code it is based on) are effectively dead products and no longer supported by the original authors.
However there is a new equivalent also free priece of software called forked-daapd which does support all these new feautres.
Allgededly forked-daapd has been successfully ported to the Qnap NAS see http://forum.qnap.com/viewtopic.php?f=177&t=37472 I am sure NetGear would not want to be considered inferior to Qnap Information about the forked-daapd project can be found at http://www.technologeek.org/projects/daapd/index.html and http://blog.technologeek.org/category/h ... rked-daapd and code at http://anonscm.debian.org/gitweb/?p=use ... -daapd.git
Note: I would have no problems with NetGear only adding support for forked-daapd to x86 based ReadyNAS units if that makes it more practical to achieve.
I am aware that implementing forked-daapd as-is would require updating libraries like libc on the ReadyNAS but that would be no bad thing to do anyway. Again I would point out that someone has ported forked-daapd to the Qnap which normally has the same libc issue.
UPDATE:
As many people posting support for this feature request will know, iTunes 10.5 is no longer able to work with FireFly. This makes the need for Firefly to be replaced by forked-daap even more urgent. Currently the QNAP being able to run forked-daap is the only NAS that has a solution. Time for action NetGear I think.
UPDATE:
- grimlochAspirant+1
Been waiting for this for quite some time. - grimlochAspirantBump for my birthday. This would be a great present!
- dsm1212Apprentice+1
- grimlochAspirantME GRIMLOCK WANT FORKED-DAAPD ON READYNAS!
- par9AspirantI want it too. Or some other iTunes server that works moving forward....
- k0nanAspirant+1
upgrade to forked-daapd please!
come on, QNAP has it and Netgear doesn't .. please BE above QNAP ! - dsm1212ApprenticeMuch more urgent now that itunes 10.5 is no longer compatible with Firefly. Really shouldn't claim product compatibility anymore as it is right now.
- dmccombe15Aspirant+1
- KrowtenAspirant+1
- htrimble55Aspirant+1
ITunes 10.5 fix is needed
