jelockwood1
Jul 29, 2011Guide
Please port forked-daapd to ReadyNAS to replace Firefly
Currently like all other NAS boxes, the ReadyNAs uses the obsolete Firefly (aka. mt-daapd) code. This still works (just) as a very basic music sharing server to iTunes clients, but does not support newer features like Apple Remote, Apple TV, AirPlay, etc. etc. features. Firefly (and the mt-daapd code it is based on) are effectively dead products and no longer supported by the original authors.
However there is a new equivalent also free priece of software called forked-daapd which does support all these new feautres.
Allgededly forked-daapd has been successfully ported to the Qnap NAS see http://forum.qnap.com/viewtopic.php?f=177&t=37472 I am sure NetGear would not want to be considered inferior to Qnap Information about the forked-daapd project can be found at http://www.technologeek.org/projects/daapd/index.html and http://blog.technologeek.org/category/h ... rked-daapd and code at http://anonscm.debian.org/gitweb/?p=use ... -daapd.git
Note: I would have no problems with NetGear only adding support for forked-daapd to x86 based ReadyNAS units if that makes it more practical to achieve.
I am aware that implementing forked-daapd as-is would require updating libraries like libc on the ReadyNAS but that would be no bad thing to do anyway. Again I would point out that someone has ported forked-daapd to the Qnap which normally has the same libc issue.
UPDATE:
As many people posting support for this feature request will know, iTunes 10.5 is no longer able to work with FireFly. This makes the need for Firefly to be replaced by forked-daap even more urgent. Currently the QNAP being able to run forked-daap is the only NAS that has a solution. Time for action NetGear I think.
UPDATE:
- oneclickAspirant+1
Netgear to fix this asap. - michelm_deAspirant+1
ITunes 10.5 fix is needed - justinlangAspirant+1
Update necessary - Maarten_NLAspirant+1
A working Itunes-server would be nice. - grimlochAspirant
Maarten_NL wrote: +1
Working and modern! - nsneVirtuoso+1
Now that my desktop's mothballed, I have no way to listen to my iTunes library via my satellite computers without this. - stiankdAspirant+1
I want my music back! - briany2000Aspirant+1
Please update the firmware. I am much more likely to continue buying everything Netgear (routers, switches, NAS, for friends and family as well) if the company proves that spending $1K (at the time) for my Duo with 1T of storage would be rewarded with continued support.
Do the right thing and I will continue to buy Netgear products. - JarnoGGuidePersonally I prefer to use iTunes, but since I can't for now, I'm using Firefly Client. It lacks most options iTunes has, but at least I can play my music with it.
It hasn't been updated in quite some time, so don't expect to much from it
Oh and +1 to a iTunes server that works with iTunes 10.5
