Singularity
May 01, 2019Tutor
Plex Media Server Problem
I have a Netgear ReadyNAS Pro 6 with firmware 6.10.0
For some reason I can no longer run Plex on the NAS.
Is Plex still supported on the ReadyNAS Pro 6
If not supported can I install an older f...
- May 01, 2019
you can get it directly from Plex. You select what platform its for and then select the specific package.
https://www.plex.tv/media-server-downloads/
Singularity
May 01, 2019Tutor
If I log into the NAS I can see that Plex is installed and ON.
However when I try to Launch it says 'Server Not Found'
I notice that Plex isn't in the Available Apps list on the Admin Page
So where do I get Plex from to re-install it?
Thanks
May 01, 2019Guru - Experienced User
