DrLD
Nov 26, 2015Follower
Possible to connect QNAP TS-251 to Netgear WNDR 3800?
I woukld like to buy NAS, I prefer QNAP TS-251. I have router Netgear WNDR 3800. Does the router and its switch support trunking port for connection of NAS giga ports? In the manual of the NAS they...
Nov 26, 2015Guru - Experienced User
You are posting in the wrong forum (you should be in home networking for the wndr3800).
However, the WNDR3800 does not support LACP teaming. The only router (from any manufacturer) that I know of that does support it is the Netgear R8500. Generally you need a "smart" switch.
There is one linux teaming mode that can be used w/o router/switch support. Check your QNAP manual for details.
