SuzieSmith
Feb 08, 2017Aspirant
Firmware upgrade possible ?
The model is : Netgear N300 wireless ADSL2+ modem router DGN2200v4
I am currently running firmware version V1.0.0.24_5.0.8
The 'firmware upgrade assistant ' says ..... a 'router firmware upgrade is available' .... which is 1.0.0.66_1.0.66 ....... but it won't allow me to scroll to the bottom of the page to tick. ' yes update'
Could someone please send me a link to this (or newer ) to upgrade my firmware ?
thanks for your help
suzie ( first timer to community ) 😃
Ps ......My router is about 3 years old
SORTED ......
thank you you very much Michaelkenward ..
the zip/unzip app has opened the file in iCloud through airdrop
many many thanks you you guys are wonderful ......did you all know that ???
Gee ...it's great ...I shall now proceed with the firmware upgrade
thank you thank you 😃😃😃😃😃
- netwrksMaster
Software found under downloads - upper right on this page - https://www.netgear.com/support/product/DGN2200v4.aspx
- SuzieSmithAspirant
Thanks Netwrks Master .....been there .....no good .🙁
as I am only on an iPad Air I'm thinking I'm limited and it isn't allowing me to open the download in Safari , Viber , Firefox or email to myself . I did get as far as 'browse' in one of them but then it wanted a ....*cx file ...... or something so then I was lost !
any other suggestions ?
- VE6CGXMaster
When try to scroll down the update page, what happens? Are you clicking the right arrow?
