blunderblorm
Oct 20, 2014Aspirant
Power down or freeze only on weekends???
For the last 3 weeks in a row and a few times at random before that (always on the weekend though) the ready nas 1500 (rackmount 1u) we have has shutdown or frozen. The DCT led (solid green) and the n...
mdgm-ntgr
Oct 21, 2014NETGEAR Employee Retired
Do you have a backup?
I see that at least one of your disks and possibly two are failing.
Two of your disks have a non-zero current pending sector count.
Your disks are not on our compatibility list. I don't recommend using WD Green disks.
Your Load Cycle Counts on these disks are huge. It doesn't look like you've changed the WDIDLE3 timeout.
If you look at disk_smart.log there is a problem with /dev/sdb and possibly /dev/sdc as well.
Also you are running old firmware. Once you have an up to date backup and have replaced the faulty disks (one at a time, wait for resync to complete before moving onto the next disk).
- Jan 17, 2024Retired_Member
