blunderblorm
Oct 20, 2014Aspirant
Power down or freeze only on weekends???
For the last 3 weeks in a row and a few times at random before that (always on the weekend though) the ready nas 1500 (rackmount 1u) we have has shutdown or frozen. The DCT led (solid green) and the n...
blunderblorm
Oct 21, 2014Aspirant
You are correct about those load cycles being huge, in fact they are twice what the WD greens are rated for (300,000) I believe that green drives unload heads often to save power. Which might be why that is so high. I probably should change the WDIDLE timeout.
I will replace those drives after going through the smart data and also update the firmware.
- Jan 17, 2024Retired_Member
