kai_sf
Mar 02, 2018Follower
Power loss during file transfer
Hi - I'm a brand new user - and just purchased and set up my first NAS for home use... Question: I was transferring the contents of my music library from an external harddrive to ReadyNAS via U...
Mar 02, 2018Guru - Experienced User
kai_sf wrote:
if I start the copy all over again - will it duplicate existing files or give me the option to skip those? Or is there a better approach to address this situation?
That depends on how you were you doing the copy.
BTW, if you were doing drag+drop from a PC you would get better performance by hooking up the USB drive to the PC. Otherwise the data gets pulled to the PC from the NAS and pushed out again from the PC back to the NAS.
If you are copying from a PC, then a utility that can verify (or at least resume) would be the best approach. Teracopy for instance.
