CharlieOH's avatar
Apr 24, 2024
R8000P Nighthawk X6S gives no flashing power light during firmware upgrade process
Netgear R8000P Nighthawk X6S AC 4000 WiFi Router
Firmware update of my R8000P using the GUI fails.  When I try to use the TFTP client the instructions say to:
   8. Turn your router off for 10 seconds.
   9. Turn your router back on.
   10. Wait for the Power LED to light orange and start flashing.
   11. When the Power LED is flashing, click Put in Tftpd64 to initiate the firmware upload.
The power LED turns orange after power off and back on, but never flashes.  It stays solid orange and then changes to solid blue, never having flashed.
Suggestions?
