dbricca
Dec 22, 2008Aspirant
Power Off Button!!!
I am astonished that I can't choose to power off this unit with the push of a button. It has got to be THE MOST ANNOYING aspect of this otherwise very well designed NAS box. I thought the ReadyNAS Du...
lanman555
Sep 05, 2012Aspirant
The Readynas Duo V2 power button must be pressed quickly twice to start the shut-down sequence. Read the 'hardware manual'.
Use of the power button only seems to work once the device is fully booted. To check if the device is fully booted up use the Raidar software utility.
