virwin's avatar
virwin
ReadyNAS Pro Pioneer getting power but blue power button not working
I have an old ReadyNAS Pro Pioneer that has been working perfectly. We had a power outage last night and the unit was on UPS power for about 10 minutes. While on UPS power, I powered the ReadyNAS down safely using the blue power button (press and hold and then press again). I then flipped the switch on the back of the unit OFF as an extra precaution and went to bed.
This morning I am trying to power it back up but am having problems. After flipping the switch on the back to the ON position, I can see that the unit is getting power successfully as the ethernet port has a healthy green light. But the blue power button on the front does not light up at all and pressing it gets no response. This has never happened before. I have checked the forum postings but have found no clear answer. I tried calling techincal support but was directed to an online link that doesn't exist and then disconnected.
I'll be extremely grateful for any help or suggestions.
  • StephenB's avatar
    Try disconnecting the power, removing the disks (labeling them by slot number), and then power it up diskless.  Then see if it boots with a no-disk status.  If if does, then also see if RAIDar detects it.
    You might have a coincidental PSU failure (it's not that uncommon for them to fail when being powered up).
    • virwin's avatar
      virwin
      Ok, I will try it and report back. Thank you so much for your reply.
      • virwin's avatar
        virwin
        Ok, I tried it. I disconnected the power and removed the disks. Then reconnected the power and tried to power it up, and unfortunately there was no change. The ethernet port still gives a green solid light, but the blue power button on the front does not light up and does not respond.
        If it was a power supply failure, does it make sense that the ethernet port light is lighting up?
        Thanks again.
ProSupport for Business
