virwin
Apr 02, 2018Aspirant
ReadyNAS Pro Pioneer getting power but blue power button not working
I have an old ReadyNAS Pro Pioneer that has been working perfectly. We had a power outage last night and the unit was on UPS power for about 10 minutes. While on UPS power, I powered the ReadyNAS dow...
- Apr 10, 2018
Well I am happy to report that I was able to get the power supply switched out successfully. I put all the disks back in and everything came up fine and is back to normal with no problems at all. If anyone is reading this and looking for the parts, I found them here:
https://www.amazon.com/gp/product/B004JUXQU8 (Seasonic SS-300SFD)
https://www.amazon.com/gp/product/B000FL60AI (extension cable)
Thanks very much to Sandshark and StephenB for your assistance.
Apr 02, 2018Guru - Experienced User
Try disconnecting the power, removing the disks (labeling them by slot number), and then power it up diskless. Then see if it boots with a no-disk status. If if does, then also see if RAIDar detects it.
You might have a coincidental PSU failure (it's not that uncommon for them to fail when being powered up).
- virwinApr 02, 2018Aspirant
Ok, I will try it and report back. Thank you so much for your reply.
Ok, I tried it. I disconnected the power and removed the disks. Then reconnected the power and tried to power it up, and unfortunately there was no change. The ethernet port still gives a green solid light, but the blue power button on the front does not light up and does not respond.
If it was a power supply failure, does it make sense that the ethernet port light is lighting up?
Thanks again.
I have been looking into replacing the power supply and found this posting. Amazon has the Seasonic SS-300SFD 300W the poster recommends.
Would you recommend going this route? It's probably too much to hope for, but is it possible there is just some sort of reset needed? It was working beautifully until I powered it down last night. Replacing the chassis looks to be quite expensive.
Thanks for any suggestions you can offer.
