virwin
Apr 02, 2018Aspirant
ReadyNAS Pro Pioneer getting power but blue power button not working
I have an old ReadyNAS Pro Pioneer that has been working perfectly. We had a power outage last night and the unit was on UPS power for about 10 minutes. While on UPS power, I powered the ReadyNAS dow...
- Apr 10, 2018
Well I am happy to report that I was able to get the power supply switched out successfully. I put all the disks back in and everything came up fine and is back to normal with no problems at all. If anyone is reading this and looking for the parts, I found them here:
https://www.amazon.com/gp/product/B004JUXQU8 (Seasonic SS-300SFD)
https://www.amazon.com/gp/product/B000FL60AI (extension cable)
Thanks very much to Sandshark and StephenB for your assistance.
virwin
Apr 05, 2018Aspirant
Cool. Thanks for the tips. I should receive the power supply early next week and I'm looking forward to working on it. I am eager to get this fixed as the NAS is my interface to cloud backups, so I'm doing local-only backups for now while it's out of commission.
I'll write back, hopefully with good news of my success :-) after I work on it next week. Thanks again for your help. I really appreciate it.
virwin
Apr 10, 2018Aspirant
- virwinApr 10, 2018Aspirant
Looks like that power supply link isn't working, here it is again:
- StephenBApr 10, 2018Guru - Experienced User
I'm glad you are up and running again.
- SandsharkApr 10, 2018Sensei
And lucky to have gotten the supply when you did. Both Amazon and NewEgg are now out of them.
Hmm. I got mine from a third-party seller called "Thousands of Electronics". It looks like that seller still has at least one for sale:
https://www.amazon.com/gp/offer-listing/B004JUXQU8/ref=dp_olp_0?ie=UTF8&condition=all
It is listed as "used" but the one I received was as good as new and had no signs of use. And yeah they are definitely out of stock at New Egg.
- StephenBApr 11, 2018Guru - Experienced User
These models aren't listed at Seasonic.com, so they must not be in production anymore. It'd be useful if someone could research alternatives. Silverstone makes a supply with similar dimensions (SST-ST30SF), not sure if it would serve or not.
- SandsharkApr 11, 2018Sensei
StephenB wrote:
virwin wrote:And yeah they are definitely out of stock at New Egg.
I've suggested the SST-ST45SF elsewhere on the forum, but have not seen where someone has used it. The higher rating of 450W vs. 300W bumps the 12V rail up to the Seasonic rating, and there is also a higher rating on the +5VSB, which I know has been the problem for some. Only $10 more than the SST-ST30SF. But neither have the 3 4-pin MOLEX connectors. The NAS might work fine with just 2 (I know it has just for recovery operations), but Netgear put on three for a reason. So a SATA to MOLEX adapter or moving one of the connectors from old to new would be recommended. I've always moved the old connectors and trimmed the leads, anyway; as it's cleaner.
I bought 4 SeaSonics from another dealer on closeout a few years ago and still have two. Plus, my legacy 6-drive units aren't in my current production environment. So, I'm not likely to try one any time soon.
