vasyam
Sep 26, 2020Tutor
ReadyNAS Pioneer Pro OS6 volume missing after hard reset
Hello,
I am running OS6.10.3 on my legacy RNDP6000-100 Pioneer Pro. It works generally fine but freezes someties and the only way to unfreeze it was to perform a hard reset which also worked generally fine until this morning. After a usual resync I got the volume missing error message with all discs being shown as working fine.
It seems that this issue does occur regularly so hope there is a ready solution.
TIA
Got it, thank you
There must have been pending disk writes when you did the hard reset - resulting in an out-of-sync RAID array.
The puzzle here is to understand why the system hangs. One possibility is that it has insufficient memory. Are you using the stock 1 GB, or have you upgraded the RAM?
