PatrikLindqvist
May 12, 2020Aspirant
Power supply failure RNDU4000
I have just got a problem with my RNDU400 Ready Nas. It goes on for 5-10 seconds and then die, so i guess it´s something with the power. Or if someone had the same problems and have any tips to solve...
PatrikLindqvist
Thanks Stephen for a very nice and thourough reply.
I did try to remove the disk and power it up again but same thing, it run only for 4-5 seconds and then just died. So it would not be possible to see if the PSU is faulty to see if there is any indication for "no disk".
Any idea if this could be more related to the power supply and maybe rule out PSU problems?
I will look into more of your points very soon.Thanks again for your kind reply!
PatrikLindqvist
I´m sorry for my incompitent reply about PSU meaning power supply unit ;). I´m not so familiar to the term as im Swedish, i thought it was the motherboard or similar.
Any suggestions to rule out the PSU or that the PSU is the main problem regarding the 4-5 second abrubt shutdown?.
I will continue to search for another newer NAS to try to switch the disks.
- StephenBMay 12, 2020Guru - Experienced User
If you have an old ATX power supply, you could get an extension cable and modify the pinout in the cable. Then temporarily connect it to the NAS and see if it stays up. But that assumes that you have such a supply on hand.
Perhaps Sandshark will have a couple of simple troubleshooting steps.
- SandsharkMay 12, 2020Sensei
It does sound like a hardware problem.
The failure of one of the power supply voltages could cause that behavior. A faulty thermal sensor could, too, with the NAS protecting itself from what it believes to be an overheating situation. It's unlilkey a real overheat problem happens that quickly. I'm not sure if a bad fan (or speed sensor for it) can also do that, but I don't belive so.
The first thing is to assess how much time and money you want to put into that old, somewhat slow NAS. If you feel it's worth it, the use of an external power supply with an adapter cable is about the only thing you can do easilly. There is a TTL level UART port you can connect a terminal to with the right adapter and see if you see any BIOS messages, but that starts to get a little complicated. Beyond that, there is not much that can be done since Netgear has not provided schematics.
- PatrikLindqvistOct 23, 2020Aspirant
Thanks Sandshark for your reply. I lost the tab and couldn´t find my way back to the forum. Things has been on hold for a while.
I just replied to Stephen who had some ideas. That i bought the same cabinett as the broken one. Would you know if i just do a system reset, mount the disc in the same slot and then power up that it would work? or do you know if i need to do anything else for it to work, maybe this doesn´t work anyway. Would be very greatful for any advice.
Thanks a lot Stephen. I lost the tab for this thread and couldn´t find my way back.
So finally i found another cabinett for the same model as the broken one. Would you know if i just do a system reset, mount the disc in the same slot and then power up that it would work? or do you know if i need to do anything else for it to work, maybe this doesn´t work anyway. Would be very greatful for any advice.
- StephenBOct 23, 2020Guru - Experienced User
There's no need to do a reset (and in fact you can't if you have no disks installed).
What you should do is install a scratch disk first, and make sure the chassis is working properly. After initial setup, try powering down the NAS, and shift the disk to bay 2 - making sure that the NAS boots properly. Repeat that test for the other bays.
Then check that the correct firmware is installed. Match the version in your old NAS (if you remember it). If you don't, then install the newest firmware.
After that, power down the NAS, and remove the scratch disk. Then migrate your disks to the new NAS, preserving the slot order.
