Sugru
Aug 08, 2016Aspirant
Power supply replacement Ultra 4
I've had a Ultra 4 stored unused for the last few years. When connecting it to power today, the power supply died violently( blowing my 16A circuit breaker for the room). I took the power supply ...
- Aug 18, 2016
If it's just to migrate the data, I recommend you buy an ATX power extender and just clip the -5V and -12V lines. Or, if the supply is "expendable", just clip the wires directly. Your unit will probably run fine on a standard ATX supply without the extra +12V long enough for you to extract the data. Of course, you may have already killed the -5V and -12V on that supply by mating them with +12V in the NAS.
mdgm-ntgr
Aug 09, 2016NETGEAR Employee Retired
ReadyNAS Ultra 4 PSU is modified FSP120-40LE. The pinout is different from standard ATX PSU where -12V and -5V are used for 12V.
Unless your PSU does not output -12V/-5V, a standard PSU can’t be used.
