Sugru
Aug 08, 2016Aspirant
Power supply replacement Ultra 4
I've had a Ultra 4 stored unused for the last few years. When connecting it to power today, the power supply died violently( blowing my 16A circuit breaker for the room). I took the power supply ...
- Aug 18, 2016
If it's just to migrate the data, I recommend you buy an ATX power extender and just clip the -5V and -12V lines. Or, if the supply is "expendable", just clip the wires directly. Your unit will probably run fine on a standard ATX supply without the extra +12V long enough for you to extract the data. Of course, you may have already killed the -5V and -12V on that supply by mating them with +12V in the NAS.
JohnRo
Aug 15, 2016NETGEAR Employee Retired
Hi Sugru,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
Sandshark
Aug 18, 2016Sensei
- SugruAug 18, 2016Aspirant
Hi, thanks for the advice, I have an atx extender cable on order, so will modify that when it arrives and power up again..
I guess I'll have to see what happened to my power supply, it doesn't have any -5V as pin 18 is unused on newer ATX power supplies, so it's the -12V that may be the issue.
The important bit is that my Ultra 4 mainboard should be ok?, even though I connected the ATX supply before I knew the wiring was modified..
I see the comment above about FSP120-40LE, the original power suplly on my Ultra 4 is an FSP060-40LE, 60W, but the wiring does indeed match the pinout with regards to colours..
- SandsharkAug 18, 2016Sensei
How that affected your motherboard depends on the archetecture of the supply. -12V typically has very limited current capability, and dead shorting it to +12V likely would crowbar it (shut it down), and thus no damage would result to the motherboard. If there is no crowbar circuit, then the -12V would probably burn out, again with no significant impact to your system since it has such limited current capacity compared to the +12V.
