DBeidle
Jan 15, 2017Initiate
Power Supply Replacement
I have a ReadyNAS 1100 Model RNR4450-100NAS that I bought in January 2008. It won't power on so I suspect a bad power supply. I see that Amazon.com has a replacement Seventeam ST-220FUB-05E power...
ksdst1
Jul 21, 2017Aspirant
Hi Stephen. I came across your post because I am replacing the same Seventeam ST-220FUB-05E PS, but not for the NAS. It is an OWC mac array. It is your link to pin out. I need to use the green lead for a switch but don't know what pin to use for the black (I guess ground). I can't tell from the original PS b/c the wiring is slightly different. I'm not an EE type guy. Any suggestions would be much appreciated.
VKGH
Jul 21, 2017Tutor
Normally, in order to switch a PSU on in order to test it, I connect the green with any other black wire (ground) and it works. the PSU Seventeam ST-220FUB-05E PS is a standard ATX PSU but is is also widely modified and used for other systems such as Netgear ReadyNAS Boxes. This often lead to confusion.
- cdubeaJul 22, 2017Aspirant
Thanks for the info. I've got a NV+ with a dead PSU.
Has anyone had a look at these:
Cheers,
chris
- SandsharkJul 22, 2017Sensei
While the supply used in many legacy 4-bay systems is labeled as being a Seventeam ST-220FUB-05E, it has a modified pin-out from the standard supply and, except for the very earliest Infrant NV, no fan, additional ventilation holes, and a mount for the cooling air deflector.
The one you are looking at has a fan based on the other systems listed as compatible, I don't think it has the modified ATX pin-out, either (so they are wrong about the compatibility listing). But it is one of many supplies that can be modified to work. You will have to change the pin-out of the ATX connector, remove the fan, replace the cover with your old one, and you may need a cable extension.
- VKGHJul 22, 2017Tutor
A new replacement PSU suitable for Readynas NV, NV+, NVX, 1100, 1500 & 2100 is available from the UK here:
