szlevi's avatar
szlevi
PowerConnect 2816
Seems to be working fine though for some reason I am still unable to ping it with jumbo frame-sized packets... any idea from other 28xx users?
  • Weird. Sometimes it's working one way then stops...
    naspro:/c# ping -s 9000 192.168.1.2
    PING 192.168.1.2 (192.168.1.2) 9000(9028) bytes of data.
    9008 bytes from 192.168.1.2: icmp_seq=1 ttl=64 time=2.11 ms
    9008 bytes from 192.168.1.2: icmp_seq=2 ttl=64 time=2.16 ms
    9008 bytes from 192.168.1.2: icmp_seq=3 ttl=64 time=2.14 ms
    9008 bytes from 192.168.1.2: icmp_seq=4 ttl=64 time=2.19 ms
    9008 bytes from 192.168.1.2: icmp_seq=5 ttl=64 time=1.41 ms
    9008 bytes from 192.168.1.2: icmp_seq=6 ttl=64 time=2.11 ms
    9008 bytes from 192.168.1.2: icmp_seq=7 ttl=64 time=2.15 ms
    9008 bytes from 192.168.1.2: icmp_seq=8 ttl=64 time=2.18 ms
    9008 bytes from 192.168.1.2: icmp_seq=9 ttl=64 time=2.17 ms
    9008 bytes from 192.168.1.2: icmp_seq=10 ttl=64 time=1.53 ms
    9008 bytes from 192.168.1.2: icmp_seq=11 ttl=64 time=2.33 ms
    9008 bytes from 192.168.1.2: icmp_seq=12 ttl=64 time=1.50 ms
    ^C
    --- 192.168.1.2 ping statistics ---
    12 packets transmitted, 12 received, 0% packet loss, time 11012ms
    rtt min/avg/max/mdev = 1.412/2.003/2.333/0.304 ms
    Time to give up, almost 4AM - I'll call Dell tomorrow morning.
  • OK, so it so far does not work with any oversized packet...
    Now the only setting on my switch' web UI mgmt page is under Advanced Settings/General is Enable or Disable JF at next boot; currently it's on.
ProSupport for Business
