Mathiaslink
Oct 02, 2014Aspirant
Pre purchase planning
I have two identical formatted WD 1TB drives sitting around..they're new. Can I just buy the two bay product, plug in the drives and go from there?
Oct 02, 2014Guru - Experienced User
Check the hardware compatibility list for the RN102 and the RN312 here: http://kb.netgear.com/app/answers/detail/a_id/20641
If your drives are not listed, then Netgear will deny support if you have an issue.
