Mathiaslink
Oct 02, 2014Aspirant
Pre purchase planning
I have two identical formatted WD 1TB drives sitting around..they're new. Can I just buy the two bay product, plug in the drives and go from there?
Marto731
Oct 03, 2014Aspirant
Mathias,
From my support days, I have not heard of any issues with using 2 x 1 Tera WD drives
that you describe.
You will need to Factory reset which will wipe them.
Install of ReadyNAS OS6
http://kb.netgear.com/app/answers/detail/a_id/7005
Can I move Duo/ NV+ /Stora disks into OS6 NAS?
http://kb.netgear.com/app/answers/detail/a_id/7007
Regards, Marto
that you describe.
Regards, Marto
