eton
Oct 22, 2023Luminary
Prefered/supported HDD block size for RN300 series?
Which hard disk drive block sizes (bytes per logical sector) are supported by RN312?
Toshiba has these types: 512e (emulated), 512n (native) and 4Kn.
Does it matter? Will any performance change be noticeable with another block size?
My own drives (mostly WD Red Plus and Ironwolf) are 512e.
I haven't seen a 512n drive in a long time - what drive models are you looking at?
- etonLuminary
Thanks. So 512n is the oldest type.
I've been looking at WD Red Plus and Ironwolf and also Toshiba MG and Toshiba N300.
But I get a bit confused if Toshiba's MAMR disks supports CMRm when reading the data sheet for the MG model:
https://www.toshiba-storage.com/products/enterprise-capacity-hard-drive-mg-series/
- SandsharkSensei
Under OS6 at least, ReadyNAS volume sector size is 4k, so the OS can handle 512(n or e) or 4K sectors. Presumably mixed, but I've never tried it. I don't think you'll see any significant difference performance-wise. But like StephenB, all mine are 512e.
This may help regarding the Toshiba drives: https://www.toshiba-storage.com/trends-technology/hamr-vs-mamr-microwave-technology-delivers-higher-storage-densities-in-hard-disks/
But long story short, MAMR is not SMR and does not have the same drawbacks. Nonetheless, it's a newer technology without a lot of real-world use to verify longevity.
