Westyfield2
May 03, 2013Tutor
Pro 6 - 2x2GB PC2-6400 800MHz
Tested the below in a ReadyNAS Pro 6. Works fine, and ran the Memory Test for 8 hours (8 complete passes, and part way through the 9th) before I stopped it. Heat spreaders on them are tiny, so not a problem at all fitting :).
Crucial Ballistix Sport 4GB (2x2GB) DDR2 PC2-6400C5 800MHz Dual Channel Kit (BLS2CP2G2D80EBS1S00CEU)
Manufacturer link.
Part Number: BLS2CP2G2D80EBS1S00CEU
Module Size: 4GB kit (2GBx2)
Package: Ballistix 240-pin DIMM
Feature: DDR2 PC2-6400
Specs: DDR2 PC2-6400 • CL=5 • Unbuffered • NON-ECC • DDR2-800 • 1.8V • 256Meg x 64
Paid £47.99 (delivered) from Overclockers UK.
Manufacturer link.
