dlevens
Mar 22, 2012Aspirant
Pro 6 Memory Upgrade to 8gb - 5 passes - WORKING
ReadyNAS Pro 6 RNDP6000-200NAS Firmware v4.2.19 Memory Upgrade Info Patriot Memory Gaming Series 8 GB (2 x 4 GB) DDR2 PC2-6400 5-5-5-12 Dual Channel Kit PGS28G6400ELK *memory reports in Fron...
InTheShires
Mar 23, 2012Tutor
Why does the Pro/Ultra 6 use DDR2, while the lower spec' unit like the Ultra 2+ uses DDR3?
I'll try a some Patriot though, it's worth the gamble.
