dlevens
Mar 22, 2012Aspirant
Pro 6 Memory Upgrade to 8gb - 5 passes - WORKING
ReadyNAS
Pro 6 RNDP6000-200NAS
Firmware
v4.2.19
Memory Upgrade Info
Patriot Memory Gaming Series 8 GB (2 x 4 GB) DDR2 PC2-6400 5-5-5-12 Dual Channel Kit PGS28G6400ELK
*memory reports in Frontview as 8192 MB [6-6-6-18 DDR2]
Purchase Info
$142 from Amazon
http://www.amazon.com/gp/product/B002XGUHMU/ref=oh_o00_s00_i00_details
Memory Test Info
Memory fit into unit with a little room to spare even with the large heat-dispersing shields, so no need to worry about closing the side.
I ran 5 full passes using the built in ReadyNAS memory test and no errors reported. To do 5 passes took around 13 hours.
Dennis
Firmware
v4.2.19
Memory Upgrade Info
Purchase Info
$142 from Amazon
Memory Test Info
Dennis
AMRivlin wrote: Please see my post here for the memory that works.
This is not officially supported.
viewtopic.php?f=110&t=48085&hilit=patriot&start=45#p342169
If you don't want to read the other post, here is the ram I purchased
http://www.frys.com/product/6416292?sit ... IN_RSLT_PG
I paid $100+tax, it is now $150
Thanks, I'll have a look. :thumbsup:- AMRivlinApprenticeShire, that is DDR2 for the Pro6, so it wont help you
