Munber54
Jan 27, 2013Aspirant
Pro 6 Pioneer price with vs without hard drives
Hi. After reading lots of NAS reviews and comments I finally narrowed down my choice to the ReadyNAS Pro 6 Pioneer, with 6 WD RED WD30EFRX hard drives. However it seems Amazon.com has an empty one for...
Munber54
Jan 28, 2013Aspirant
Ok, that helps a lot...thanks for your quick help. I'll probably go with the RNDP6000-200 already populated with the enterprise drives if I can find one in Canada...I guess the ones already populated would be put thru a bit of testing to make sure it's working ok....I also want to order 2 extra drives just incase I need to replace a failed drive, so I'd like to know the make and model of the drives that are in the NAS...do you know which drives they are? I looked here http://www.netgear.com/images/ReadyNAS_Pro_Series_DS_26Apr1118-13987.pdf but couldn't see the drive models.
