jessetaylor
Feb 11, 2013Aspirant
Pro 6 SYS Fan Speed Override
Folks - Forgive me if I have missed this, but can't seem to find anything. My question: Is there a fan RPM override capability for the SYSTEM fan in the Pro 6? My SYS temps are a little high...
harmakhis
nope it cant motherboard regulate its speed but it seems to grew up with cpu load, internal temp higher you have certainly due to your hdds
in mine i mount a 60mm on the heatsink regulated manually with zalman resistor
for the 12cm i removed it this poor fan an replace by a noctua NFP12 PWM
for the 8cm in PSU i removed it and replace by noctua NFR8 PWM
those fans are in another level of quality and efficience as originals....
and the NAS is in another world of silence
totaly confident in those fans, running 24/7 in my watercooled PC SSO bearings garanted silence over years
