WildPhydeaux's avatar
Jan 24, 2022
Pro Pioneer Keeps Hanging
Based on some research here after I found my RN frozen and no longer able to boot, even to the boot menu, it seemed the power supply was bad. I tested the theory with another supply and it booted ok,...
  • WildPhydeaux's avatar
    WildPhydeaux
    Jan 26, 2022
    Just following up on this thread to close. StephenB was extremely helpful in diagnosing the issue, which ended up being faulty hard disks. Wonderful that some folks here are not only wildly talented and knowledgable, but also cheerfully willing to help those in need.
    Cheers Stephen!
    Robert
ProSupport for Business
