ronron's avatar
ronron
Problem mount NFS after rest factory and update firmarework (1.10.3)
Hello,  I had updated my readyNAS. I try to share my folder via NFS.   [ Spoiler ] Any NFS options do not change the /etc/export. it is RO and the hosts do not change. Why export home ? From ti...
  • Sandshark's avatar
    Aug 16, 2020
    In the screen dump you uploaded, you are adjusting the SMB configuration, not NFS.  If you want to change NFS options, NFS must be selected in the second row of buttons.
ProSupport for Business
