ronron
Aug 16, 2020Aspirant
Problem mount NFS after rest factory and update firmarework (1.10.3)
Hello, I had updated my readyNAS. I try to share my folder via NFS. [ Spoiler ] Any NFS options do not change the /etc/export. it is RO and the hosts do not change. Why export home ? From ti...
- Aug 16, 2020
In the screen dump you uploaded, you are adjusting the SMB configuration, not NFS. If you want to change NFS options, NFS must be selected in the second row of buttons.
Sandshark
Aug 16, 2020Sensei
ronron
Yes I saw that, under the old OS it was indication tags.
Its tabs are a little bad
