xavman
Jan 17, 2016Aspirant
Problems setting up readynas nv+
not a tech head by any means.. husband used to handle this but now has a brain injury and can't speak. have recently had our pc re-built and is now not recognising the readynas, have entered the isp...
DaneA
Jan 18, 2016NETGEAR Employee Retired
Hi xavman,
As a follow-up to mdgm's response unto you, kindly check this article as reference guide on how to perform OS reinstall to your ReadyNAS NV+v1.
DaneA
NETGEAR Community Team
Jan 18, 2016Guru - Experienced User
This is also in the hardware manual (personally I find the manual to be a bit clearer). http://www.readynas.com/download/documentation/HM/Duov1_NV%2Bv1_HW_en_06Dec11.pdf
