egoff's avatar
egoff
"Problems with your data volume"
On one of my ReadyNAS 3100s (6 TB), my weekly scheduled on-line filesystem consistency check is returning: "The on-line filesystem consistency check detected problems with your data volume. Please reboot the system with the volume scan checkbox enabled to do a full filesystem consistency check and repair." I did that, and the next consistency check was clean, but now the "problems" message has returned. What's the likely cause? What should I do?
1 Reply
  • Here are the relevant log entries (one successful file system check, followed by two failed file system checks that resulted in the error message I described in my previous post). What on earth does it mean by "Possibly non-existent device?"? The ReadyNAS can't find its own file system in order to check it?
    ***** Volume maintainance: Online file system check performed at Sun Apr 22 15:00:06 2012 *****
    Warning! /dev/c/c_2012_04_22_15_00 is mounted.
    Pass 1: Checking inodes, blocks, and sizes
    Pass 2: Checking directory structure
    Pass 3: Checking directory connectivity
    Pass 4: Checking reference counts
    Pass 5: Checking group summary information
    /dev/c/c_2012_04_22_15_00: 400/91185152 files (14.8% non-contiguous), 537260178/1458962432 blocks
    ***** Volume maintainance: Online file system check performed at Sun Apr 29 15:00:02 2012 *****
    ***** Volume maintainance: Online file system check performed at Sun May 6 15:00:02 2012 *****
