jreiners's avatar
jreiners
Question on X-RAID2 RAID6
I'm the proud owner of the RN-428 with now current non beta firmware, When I set the device up a few weeks ago I only had a hodgepodge of 2TB, 5TB, and 6TB disks. I went and purchased another 6 8T...
  • Sandshark's avatar
    Sandshark
    Aug 30, 2019
    You can safely add another drive (to an empty slot) during a re-sync.  Replacing one that's a part of an active array is asking for trouble, even with RAID6.  Either way, it's not going to decrease the required re-sync time unless you will simply not be available to add the next drive when the time comes.  The OS will sync one drive, and then the next.
ProSupport for Business
