jreiners
Aug 28, 2019Aspirant
Question on X-RAID2 RAID6
I'm the proud owner of the RN-428 with now current non beta firmware, When I set the device up a few weeks ago I only had a hodgepodge of 2TB, 5TB, and 6TB disks. I went and purchased another 6 8T...
- Aug 30, 2019
You can safely add another drive (to an empty slot) during a re-sync. Replacing one that's a part of an active array is asking for trouble, even with RAID6. Either way, it's not going to decrease the required re-sync time unless you will simply not be available to add the next drive when the time comes. The OS will sync one drive, and then the next.
Aug 29, 2019Guru - Experienced User
FWIW, XRAID2 is NOT the same as RAID-6. Normally XRAID is has single redundancy - not dual redundancy. Unless you did something in the original setup (that is, switching to flexraid, selecting raid-6, and then switching back to XRAID), you only have single redundancy. That is a combination of RAID-1 and RAID-5 if you have mixed disk sizes. If that's your situation, then you certainly would have lost data if you'd hot swapped a second disk before the first resync was completed.
jreiners wrote:
I have noticed I'm up about 3TB from last night to 20TB now, with 4 more disks to go I should have it done by mid September :)
The capacity rule is "sum the disks and subtract the largest". That will give you the approx. size in TB. The NAS (like windows) reports TiB. Google will convert this for you. For instance, entering "8 TB in TiB" will give you ~7.27 TiB.
jreiners wrote:
It would take similar times just to reload the data, even with my bond.
Actually it won't. Every disk you add will take longer to resync. And it will require either reading or writing every sector in the entire volume (on all disks). You'll be doing that several times before you are done. It's much faster to build the volume once and then restore the data.
That said, there's nothing wrong with your process - as long as you are aware a disk failure during resync can result in losing all your data.
jreiners
Aug 29, 2019Aspirant
When I first set it up, it was XRAID with single redundancy, but I deleted that volume and created a XRAID2 RAID 6 instead, I have all 8 bays full, I don't want single redundancy. It shows in the web admin page it is a X-RAID (lit) and RAID 6.
My backup is offsite, and with 32TB of data, it'll take a long time with the cable modem upload on the other side, I could sneakernet but it'se just not worth it, the data has millions of small files and ~100ms latency since the other side is a cable modem. This is not critical data, and I don't care if it takes a while, it's 64TB RAW.
- SandsharkAug 30, 2019Sensei
