jreiners
Aug 28, 2019Aspirant
Question on X-RAID2 RAID6
I'm the proud owner of the RN-428 with now current non beta firmware, When I set the device up a few weeks ago I only had a hodgepodge of 2TB, 5TB, and 6TB disks. I went and purchased another 6 8T...
- Aug 30, 2019
You can safely add another drive (to an empty slot) during a re-sync. Replacing one that's a part of an active array is asking for trouble, even with RAID6. Either way, it's not going to decrease the required re-sync time unless you will simply not be available to add the next drive when the time comes. The OS will sync one drive, and then the next.
jreiners
Aug 29, 2019Aspirant
When I first set it up, it was XRAID with single redundancy, but I deleted that volume and created a XRAID2 RAID 6 instead, I have all 8 bays full, I don't want single redundancy. It shows in the web admin page it is a X-RAID (lit) and RAID 6.
My backup is offsite, and with 32TB of data, it'll take a long time with the cable modem upload on the other side, I could sneakernet but it'se just not worth it, the data has millions of small files and ~100ms latency since the other side is a cable modem. This is not critical data, and I don't care if it takes a while, it's 64TB RAW.
Sandshark
Aug 30, 2019Sensei
