EricHaug
Dec 09, 2020Aspirant
R4312X plus expansion chassis becomes unresponsive.
Hi, The system has started becoming unresponsive. It will not respont to http requests or to ICMP pings. Holding the power button will turn it off. Holding the EDA4000 power button forces it o...
mdgm
Dec 09, 2020Virtuoso
Did the problem first occur shortly after starting the Rsync to do the restore? If so, that would suggest that the wrong path is likely.
Another possibility that could relate to Rsync is if the Rsync occured when the destination ReadyNAS volume was not mounted for some reason.
The firmware being reported as corrupt can be a symptom of a full 4GB root volume which is why I suspect this.
EricHaug
Dec 14, 2020Aspirant
Hi,
Thanks for the reply.
The rsync was occurring to a freebsd system that had the netgear raid volumes
nfs mounted.
We do not use the rsync feature of the netgear systems.
regards,
eric
