Maeve1956's avatar
Maeve1956
Raid 1 on ReadyNAS 204 with 4 discs
I just got a ReadyNAS 204 with 4 8TB hard drives yesterday.  It has 6.10.2 firmware.  It came preconfigured with Raid 5, but I want Raid 1 with a 2-disc volume, mirrored to the other 2 discs.   I h...
  • StephenB's avatar
    Feb 06, 2020
    Maeve1956 wrote:
    Can anyone advise on how to set up RAID 1 with 4 discs so that I have one data volume on 2 discs which is being mirrored to the other 2 discs?
    The mode you are describing isn't called RAID-1.  It's called RAID-10.
    So try destroying the RAID-1 volume you created, and then create a RAID-10 volume after selecting all 4 disks.
ProSupport for Business
