HerbMichael
Feb 03, 2020Aspirant
RAIDar could not find any NETGEAR storage on your network
This whole setup used to work just fine but I recently noticed it had disappeared from the LAN. Raidar gives the ubiquitous error "RAIDar could not find any NETGEAR storage on your network". Othe...
- Feb 04, 2020
I have two that don't like "green" switches, but they were damaged by a surge from a nearby lightning strike. So, you may have a partly damaged NIC, too. The "green" switches auto-adjust the voltage on the interface and apparently can have trouble when the output and input capabilities of a device are mismatched (which they normally should not be).
You may want to start looking for a replacement in case it continues to go downhill.
HerbMichael
Spot on! The ReadyNAS is connected through a (16-way) switch. When I plugged it directly into the router it was recognised and appeared on the network. Plugging it back into the switch (at another outlet) caused it to disappear again,
It seems as if it doesn't like to be connected through the switch. I can live with that but I'm still checking it out. Every other device on my LAN connects through that switch so I don't know what's peculiar about the ReadyNAS.
Anyway thans for the help Sandshark. Truly appreciated.
Sandshark
Feb 04, 2020Sensei
- HerbMichaelFeb 04, 2020Aspirant
Interesting. I asume "NIC" means the network interface within the ReadyNAS?
In fact, I might just remove the device from the LAN. I've plenty more storage space and don't need as much as I used to. I mostly wanted to know what I still had stored on it (which isn't much).
- SandsharkFeb 04, 2020Sensei
Yes, "NIC" is Network Interface Controller. It's comprised of a protocol controller (sometimes embedded in an SoC or general interface IC) and a tranceiver.
OK, thanks for all your help!
