HerbMichael
Feb 03, 2020Aspirant
RAIDar could not find any NETGEAR storage on your network
This whole setup used to work just fine but I recently noticed it had disappeared from the LAN. Raidar gives the ubiquitous error "RAIDar could not find any NETGEAR storage on your network". Othe...
- Feb 04, 2020
I have two that don't like "green" switches, but they were damaged by a surge from a nearby lightning strike. So, you may have a partly damaged NIC, too. The "green" switches auto-adjust the voltage on the interface and apparently can have trouble when the output and input capabilities of a device are mismatched (which they normally should not be).
You may want to start looking for a replacement in case it continues to go downhill.
Sandshark
Feb 04, 2020Sensei
HerbMichael
Feb 04, 2020Aspirant
Interesting. I asume "NIC" means the network interface within the ReadyNAS?
In fact, I might just remove the device from the LAN. I've plenty more storage space and don't need as much as I used to. I mostly wanted to know what I still had stored on it (which isn't much).
- SandsharkFeb 04, 2020Sensei
Yes, "NIC" is Network Interface Controller. It's comprised of a protocol controller (sometimes embedded in an SoC or general interface IC) and a tranceiver.
- HerbMichaelFeb 04, 2020Aspirant
OK, thanks for all your help!
