RickieAbbott's avatar
RickieAbbott
RAIDar438 will not Open in InternetExplorer 11
iE 11 inside Windows 8.1 will not open the NAS, it will take the admin/Password then brings up the normal Screen , but all data inside the page is BLANK... ???
works fine in Google Chrome...
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    IE11 is fairly new and major IE updates are notorious for breaking compatibility with the web-admin interface. This should be fixed in the next firmware release (6.1.5) which will hopefully be available soon.
    For now you could try a different browser or try running IE in compatibility mode for an older version.
ProSupport for Business
