kc7gr
Oct 25, 2015Aspirant
RAIDiator 6.4.0 on older hardware? (Active Directory feature)
Good day, I have a ReadyNAS NV+ v2, currently running RAIDiator 5.3.11 with four WD Enterprise 2TB drives. It works quite well, but I've noticed the Active Directory support in this version of RAIDiat...
mdgm-ntgr
Oct 25, 2015NETGEAR Employee Retired
OS6 cannot be run on your NAS.
The new NAS would have a different OS and different filesystem so simply moving the disks across is not an option.
You could either:
1. Get new disks for the new NAS and use backup jobs to copy the data across. See e.g. http://kb.netgear.com/app/answers/detail/a_id/29733/~/how-do-i-back-up-data-from-a-raidiator-5-system-to-a-readynas-os-6-system%3F
2. Backup your data, verify backup is good, move your disks across, do a factory default (wipes all data, settings, everything) then restore your data from backup.
